Truck shutting off!! Ignition ground??
Old Aug 27, 2009 | 08:15 PM
hmknight's Avatar
Your blinkers and power windows are both switched through the ignition switch. Your problem sounds a bit different than mine, I think I sent you in the wrong direction with the fusible links (sorry!) Have you taken the steering column apart and/or poked around the connections at the bottom of the column?
Old Aug 28, 2009 | 09:13 AM
unixcowboy's Avatar
Just saw this thread and thought I'd add my 0.02 ..
My connector at the bottom of the steering column came loose and I had most of your symptoms, not all but most...Mine started when I hooked up my shutdown timer.
The connectors don't stay in good because the wires seem to be about 1/4" too short. If you've been under the dash poking around, running new wires, etc. I'd suspect the connectors.
Old Aug 28, 2009 | 09:16 AM
dzl_damon's Avatar
thanks, I'll give 'er a shot and try and tighten it up! The fuses seem fine and I can't seem to find a ground. I will run a new cab-frame ground and see about that connection. HOwever, the shutdown started BEFORE I was under the dash, but this thing bounces around a lot, and there is evidence the PO was under the dash alot. Hopefully it's something like this just coming loose.
Old Sep 14, 2012 | 06:58 AM
dzl_damon's Avatar
a long overdue update on this problem for anyone finding this in a search.
The problem was the ignition switch. The ignition switch was bad for a long time and the PO installed a push button starter to get by. The failed ignition switch was causing the fusible links to blow. I replaced all fusible links with MAXI fuses and 1 of the 2 major fuses that go through the switch was popping. Replaced the switch and my problems went away, plus I had a normal key to start the truck again.
Jer12377
Feb 14, 2011 10:53 PM
chopper9451
Jul 17, 2009 10:21 AM
stroker4501
Apr 10, 2007 12:06 AM
Dodgezilla
Feb 6, 2003 12:56 AM
