Transmission
Old Nov 11, 2019 | 05:13 AM
Sasker's Avatar
Transmission
Hello looking for a little help I just installed a new to me 46 rh . Stabbed a new filter and oil in and as I give it throttle it dosent seem to shift almost seems like it shifts to neutral.. any help would be appreciated
Old Nov 17, 2019 | 05:23 PM
Sasker's Avatar
I re adjusted front band is seems to shift into 2 but going to 3rd it seems to shift into neutral
hopeing for someone to chime in
Old Nov 18, 2019 | 08:52 AM
j_martin's Avatar
You might have to actually repair it.
Old Nov 23, 2019 | 12:41 PM
Sasker's Avatar
So I adjusted the tv cable a lot loosened it up if I let completely off it will shift to 3 but as soon as I give it throttle it shifts
Old Nov 23, 2019 | 05:23 PM
nonrev's Avatar
Super Moderator
10 Year Member
I believe that the adjustment on that is like 1/16" with the motor running on the firewall side of the slot, mine liked it with no gap.
Old Nov 23, 2019 | 06:08 PM
Sasker's Avatar
I got nothing to lose I will try going the other way with the adjustment
Old Nov 26, 2019 | 06:55 PM
Sasker's Avatar
So I drove truck a bit today I replaced tv cable lever because the trans shop thought it didn’t look right went for another test drive I can get all gears but in order for it to shift I have to let right off throttle then shifts so this is forward progress atleast
Old Nov 27, 2019 | 06:15 AM
dodgenstein's Avatar
Do you have to let off for each shift or just OD?
Old Nov 27, 2019 | 07:00 AM
Sasker's Avatar
Overdrive seems to be working just fine actually
Old Nov 27, 2019 | 09:45 AM
cougar's Avatar
You are close. I think all you need to do is slide the housing in the clamp a little further forward and you got it.
Old Nov 28, 2019 | 11:18 PM
Sasker's Avatar
So I have the cable as loose as possible and i still need to let off in order for it to shift would something be sticky in the valve body?
Old Nov 29, 2019 | 09:22 AM
kensmachine's Avatar
you should never run a torqueflite Transmission 904,727.46RH,47RH with the tv cable or linkage lose or off best way to kill the trans. hold the fuel pump or carburetor at full throttle adjust the cable so you have a little gap 1/16 in siding link or none at all with the link held back.also Ken
Old Nov 29, 2019 | 09:25 AM
Sasker's Avatar
Yes I would agree this has been for testing purposes It will not hold a shift of the cable is actually adjusted to the proper spec that’s why I’m asking about the valve body
Old Nov 29, 2019 | 09:57 AM
what is the history of the transmission you put in
Old Nov 29, 2019 | 11:22 AM
Sasker's Avatar
I don’t know much history on the trans other than it sat for 5-6 years
