Transfer Case Lube
Old Jun 8, 2004 | 07:09 PM
bigred496's Avatar
Transfer Case Lube
I know this has already been asked before, but what grade of oil do i put in the transfer case, and how much, i know that the tranny takes 3.5 quarts, but what about the transfer case, and what weight, thankyou. this is for the 91 dodge by the way.
Old Jun 8, 2004 | 07:38 PM
Flake's Avatar
It should take regular 80-90wt. You might run synthetic if you feel it necessary. Just fill it up until it starts to run out the fill plug.
Old Jun 9, 2004 | 10:00 PM
fschiola's Avatar
See if this will help you.
http://dodgeram.org/tech/specs/tranfer_case.htm
If you still have your owners manual, it should be in there as well.
Old Jun 11, 2004 | 09:04 PM
bigred496's Avatar
thanks guys, i changed it out with no hassle.
Old Jun 12, 2004 | 04:59 AM
ares's Avatar
thats for the 94+ xfer cases, you dont want to put atf fluid in your 205
mknittle
Mar 11, 2015 10:47 AM
wyododge
Aug 18, 2011 07:48 AM
dssimecek
Mar 10, 2008 04:58 PM
D.S.
Apr 15, 2006 05:31 PM
