Trans Issues
Old Mar 16, 2009 | 03:59 PM
rholl77's Avatar
Trans Issues
Yesterday my trans started acting up. It usually shifts quickly but yesterday, when taking off real easy, it revved way up before it shifted. If I put the gear selector in 2nd and then shift to drive then no problems. Any Ideas? Fluid level is right where it is supposed to be. Another note, if I put the hammer down then she shifts fine. Thanks
Old Mar 16, 2009 | 04:43 PM
Thunderhog's Avatar
Does it "rev up" between low and 2nd, or 2nd and drive, or both? Cold or hot, or both?
Old Mar 16, 2009 | 08:11 PM
Old-stuff's Avatar
Check to make sure that the TV / Kickdown cable has not come loose.
The housing came loose where it snaps in at the bottum end on mine, which made it basicly inoperative. One thing to eliminate first.
Ray
Old Mar 16, 2009 | 08:29 PM
rholl77's Avatar
Its mostly noticeable between low and 2nd. Both temps but usually hot.
Old Mar 16, 2009 | 09:04 PM
archer39's Avatar
like old-stuff said check the T.V. cable adjustment. That is the only thing externally that controls the shift points.
Mopar440_6
Nov 19, 2006 05:31 PM
trik396
23
May 13, 2006 05:00 PM
Dodgezilla
Jan 23, 2005 04:14 PM
ckennedy
14
Oct 8, 2004 01:03 PM
