tranny slip
Last fall I put a Sun Coast converter in, and ajusted the bands. Itshifts fine when cold, seems to slip between 2-3 when warm. worse when at a less then full throttle.
Has anyone wired the t/v cable to the full thottle position.
I use zip ties since they are flexible, easy to remove and install. I've never tied it all the way open, but I have with only about 1/2" of travel left. If you tighten it that much it will shift very firm but it wont shift til 2500 or more rpm. I did this lil trick for pulling and racing when I wanted it to shift at higher rpms. Its worth trying and finding out where you want it.
Its built, in, and screaming. No comparison now that I have lockup. The ol 518 was still doin good though when I pulled it, I could never kill that trans. My stock flexplate was cracked though.
Does this put a lot more pressure to the cooler lines?
it just ups the line pressure so it shifts firmer and and at later rpm. You can also adust the pressure, bands, and shift delay with the trans pan off. Its in the sticky and shows you how to do this and service your trans. I did this and it helped as well with my old trans.
I zip tie mine at the throttle cable. Easier access and it works, just snip the excess off so it doesn't happen to hook on anything or hang your throttle up.
txsmokindiesel
May 19, 2009 08:03 AM
silverram323
24
Nov 9, 2003 07:48 PM
BADodge2003
Aug 24, 2003 07:22 PM
