TPS adapter
Old Sep 21, 2009 | 07:07 PM
kensmachine's Avatar
TPS adapter
I went to Cummins N.W. today to get some parts. They count find a P/N for the adjustable adapter that go under the TPS any one have a Cummins P/N thanks ken
Old Sep 21, 2009 | 08:30 PM
DNRCustoms's Avatar
thats probably gonna be a dodge part since it is something Dodge adds. Are you looking for the plastic piece that drops into the 6mm allen head throttle bolt. that the tps sits on.. If so there are plenty of us on here that have them, for as much as you would pay for the part from the dodge dealer, you could install a potentiometer to control o.d and then ditch the factory tps.
Old Sep 22, 2009 | 01:00 AM
you can buy the TPS, mount, mounting screws, wire end,but they don't show the adapter. The TPS works but wont stay adjusted set it at 1volt and it ***** into 4th about 40mph then it just creeps up to about 1.3volts and it shifts into 4th at about 50mph. when its set right its alot nicer to drive the truck on the road I live on as the speed limit is 50mph. if set right it only down shifts 2-3 times in 8 miles but if the voltage is set high it ***** in and out all the time. so I lock the OD out Ken
Old Sep 22, 2009 | 12:36 PM
GasganoFJ60's Avatar
My TPS was giving me problems...so I got rid of it.
https://www.dieseltruckresource.com/....html?t=142641
whosdunit
May 17, 2014 08:54 AM
gunracer1
Sep 16, 2003 08:57 PM
boughtadodge
Jul 12, 2003 03:27 PM
w4xtc
May 7, 2003 08:23 AM
