Torque settings needed
Does anyone happen to know the torque setting for the nut on the front of the injection pump on my 1991 D-350 and the exhaust manifold bolts, doing a little maintenance this weekend.
Thanks in advance.
Jim
Thanks in advance.
Jim
in the sticky
Manifold sequence- cylinder4,3,5,2,6,1. Or 3,4,2,5,1,6. Start in and work out. When the manifold is loose you can barely get all 12 in, once you tighten the middle 2 cylinders, the next two get tight, and the outer 2 get loose. There's a lot of "squish" there.
Dodgezilla
Nov 12, 2003 09:16 AM
Dieselhead
Jun 5, 2003 10:33 PM
