Timing adjustment
Timing adjustment
Just reciently checked the "KDP" and secured it, bought the Blue Point wrench to adjust the timing. I loosen the three bolts on the pump housing and one on the rear braket, and one metal vacuum line and and used a blont punch and tappet it on one of the wings where the bolt face. I was tapping perty good and that mama jama was not moving, did I miss some other bolts?
take a wratchet strap and hook it to somthing stationary across from the pump and give it a few cranks it will move. but make sure it is only a little bit some go all the way to the head others go 1/8th i went 1/8th the fuel lines act as a spring and unless you have a constant pressure on them it will not move so try the strap idea thats what i did and it worked great.
2500TurboDodge
Jul 11, 2005 10:52 PM
