Thermocouple Location?
Originally posted by Alec
I have never burned up one of these engines, so maybe I have the wrong dope, but looking at the shape of the #1 air path -- it is almost "j" shaped -- supports what I have read, which is that #1 gets less air than the other cylinders.
From the FAQ at http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
As for cooling, Hdm48 posted that he has seen a number of engines score the #6 cylinders under high HP operation due to inadequate cooling . . . the water has to flow back there past the first five cylinders.
Gasses should not get trapped around the #1 cylinder -- but this is not a condition that I am familiar with, so I can't say anything about it.
What were you doing when you toasted your engine?
Whatever, I was not looking for information, I have it.... Worked with a cummins engineer on this thing.
Ahhhh crap, run for it guys, it's the heat......
.........HEY LOOK>>WHATS THAT UP IN THE SKY...???????
BTW, watch out for Mony's mom, she wears an army boot and can kick some butt....
Pastor Bob....
.........HEY LOOK>>WHATS THAT UP IN THE SKY...???????BTW, watch out for Mony's mom, she wears an army boot and can kick some butt....
Pastor Bob....
If I remember right, there is a plug on the head near the thermostat and #1 cylinder. Anybody running a temp sensor there? I may look into this myself.
OBTW, don't trust anybody that carry's a "SHINEY" gun............
With a two tank system you have a tank above the engine level. The main fill is to this tank. A large fill line goes from the bottom of the tank to a high point of the engine cooling system. The radiator is sealed and has a small hose from the top for an air bleed and it goes back to the fill tank. The coolant is gravity fed to the engine and the small hose from the radiator constantly circulates a small amount of coolant bleeding off any air from the radiator. A sight glass in the tank shows that you are either full of coolant or not. This system eliminates all trapped air from the system.
supersonictoys
Nov 18, 2007 09:05 AM
LarryJ
14
Dec 8, 2003 12:30 AM
pwabbott
Oct 28, 2003 08:59 AM
