Temp control cable.
Temp control cable.
The cable that controls the hot/cold door in my heater box broke. Does any one know off hand if it's a dealer only item and how much of a pain is it to change? Thanks
I'd check the junkyards and such first. They are the same for gassers and Ramchargers.
Pretty straight forward to change. If you can pull the front of the dash off you can change the cable....
I poked around in there tonight and one end is behind the glove box and easy to get to and the other will be easy after I pull the dash off. I guess it will be a good time to change some burned out dash bulbs too. Thanks
Kirk T
09-20-2006 07:19 AM
hellotbone
10-07-2003 06:54 AM
Fishinghaoliboy
06-30-2003 09:38 AM
