Surging
Surging
First guys I want to thank yall for all your help. I am having the surging problem with a 99 Dodge 3500 5.9 24v. I have changed the APPS reset it several times with taking the cables off and draining the ECM, changed fuel filter even changed negative battery terminals just in case they were not grounding good and causing electrical inference. The only thing that helps and its temporary is taking the cables off for over night and then its back within 30 minutes or so. VP 44 looks to be new. It has an AirDog on it. The fuel pressure is at 14-15psi at idle. The truck doesnt have a tuner on it. Looking for help
First guys I want to thank y’all for all your help. I am having the surging problem with a 99 Dodge 3500 5.9 24v. I have changed the APPS reset it several times with taking the cables off and draining the ECM, changed fuel filter even changed negative battery terminals just in case they were not grounding good and causing electrical inference. The only thing that helps and it’s temporary is taking the cables off for over night and then it’s back within 30 minutes or so. VP 44 looks to be new. It has an AirDog on it. The fuel pressure is at 14-15psi at idle. The truck doesn’t have a tuner on it. Looking for help
aceman28
13
Aug 30, 2021 12:33 PM
canadianskye
Oct 20, 2010 06:42 PM
matthopp
Jan 30, 2008 09:09 AM
HOHN
Aug 19, 2006 09:07 AM
