Super Cool and CHEAP TPS fix! Dial-in your OD shift point!
Old Sep 13, 2010 | 12:15 PM
  #91
jesussaves's Avatar
does anyone know the specifics of each wire color? ground, signal, etc
Old Mar 27, 2011 | 09:11 PM
  #92
mopar1ton's Avatar
Smile
Originally Posted by Rammer64
Has anyone experienced any troubles or any experience with the transmission temperature sensor? As i have come to understand, that many of these OD shifting problems may be caused by the TTS which measures cold ambiant air tempurature as well as overheating transmission temps. Both low and high temps prevent the trans from shifting into OD. I've been told by a transmission shop, that by us using a potentiometer as the tps, we're defeating the TTS circuit (which may be the root cause of the messed up OD shift patterns.)
I think this could be my trouble. When the outside temp is cold it shifts in and out of OD and I can not find a "happy place" with the accelerator pedal to stop it. When it's really hot outside it almost always shifts fine. Where is the TSS sensor located? Or should I forget the TSS and just install the potentiometer?
Old Apr 11, 2011 | 09:37 AM
  #93
Scott Glenz's Avatar
I helped my dad put this in and it worked great except for the cruise control. after you set it, it will gradually increase in speed.
His truck is a 1993 3/4 ton truck
Old Apr 11, 2011 | 09:38 AM
  #94
Is there any way to fix the cruise?
Old Jun 19, 2011 | 02:22 PM
  #95
IanM's Avatar
Originally Posted by ouchman
Give it a try Denis - you'll like it.
Just remember: The TPS is "upside down" in reference to the normal pot. The potentiometer you buy will increase when turned clockwise. The one on the truck does also, but it's flipped over. Disconnect the one on the truck, flip it over, and then wire the pot in the same configuration. Get it?
Then re-install the TPS, but just leave it disconnected. That way it's easy to switch back if you need to do so.
Is it the same procedure for a 96? I've heard the TPS rotates the opposite way on the 1st gen compared to the 2nd gen...not sure if the wiring would be opposite as well. Also, in order to wire the pot, would I need to cut the connector off at the TPS, and splice into the wiring?
To set the pot to have OD kick in, do you need to use a voltmeter? Or do you guys just fiddle with it until OD kicks in where you want it?
Has anyone put together a "shopping list" for this mod? I'm terrible at electronics! From what I understand, I would need the following:
5000 ohm linear taper potentiometer
3 butt end connectors
10' braided 3 wire
Thanks for the help!
Old Jun 19, 2011 | 05:34 PM
  #96
Onemoparnut's Avatar
There is a material list in the sticky look there. I just adjust mine till it shifts where I want it.
Old Jun 19, 2011 | 08:59 PM
  #97
RCREED's Avatar
I think i have same problem with TTS. How do we check proper function of this sensor? Does POT override sensor? What about cruise problems? Thanks for any answers. Randy.
Old Jun 19, 2011 | 09:56 PM
  #98
The test procedure is in the sticky. The potentiometer does away with the tps. And the cruise will still work properly.
Old Jun 20, 2011 | 05:29 AM
  #99
baddodges's Avatar
ats diesel has the wire diagram and complete instruction on how to fix the (4th gear hunt)thats what they call it.did it to my 99 and it has never shifted better
Old Jun 20, 2011 | 10:20 AM
  #100
ouchman's Avatar
Um, so does this thread - and it's FREE.
Old Jul 1, 2011 | 10:45 PM
  #101
IanM's Avatar
I just finished installing my Potentiometer! This is a great mod, and the cash I saved went towards boost and EGT gauges
Thanks for posting Ouchman, and thanks to everyone who helped!
Old Jul 2, 2011 | 05:03 PM
  #102
IanM's Avatar
So, I had more of a chance to test out the potentiometer mod today, and had problems. I'm hoping someone can confirm my two theories...
I took some pins from a PC plug and crimped (butt-end connectors) them to the ends of the wires running from the pot, and plugged it into the female TPS plug. My first theory is that the pins aren't quite long enough, so signal from the pot to the TPS plug is inconsistent. I'm assuming this would cause the OD to disengage intermittently, like it was before with the bad TPS. It's quite a bit better than it was, but OD is still kicking out. (I've switched the two outside wires back and forth a few times)
My second theory is that the second gen TPS is more influential than the first gen, meaning the potentiometer isn't doing what the TPS did previous???
I'm thinking it's a connection problem, anyone have some thoughts?
**Edit: after spending the day fiddling around with it, cutting and recrimping all the connections and using brass pins as the TPS plug, and heatshrinking everything, it is functioning as it did before, with the bad TPS. I know all of my connections are as good as they can get without sautering them. Am I missing something? the pot should just wire directly to the female TPS plug, right?
Thanks in advance diesel gurus!!
Old Jul 28, 2011 | 06:06 PM
  #103
1cowboy's Avatar
What a great idea want to try it any pics thanks for the idea
Old Oct 1, 2011 | 03:38 PM
  #104
THEBIGBULLY's Avatar
VERY HAPPY!!!!!!
This little mod rocks and I can't believe how much it sorted out my tranny!!!
Well done
Old Aug 4, 2012 | 07:04 AM
  #105
allllchemist's Avatar
Originally Posted by Joe V
I tried bypassing my dead TPS with a POT, I can’t get it to work. I’ve read this thread numerous times to see if I missed anything.
I have the correct POT.
I’m using 18 gauge wire.
The red wire is in the center, I’ve tried switching sides on the 2 outside wires.
The truck is not charging the battery; the speedo stays at zero and the OD button light remains off. The truck died on me when I was driving it last week. After going back the next day to pick it up, I installed a fully charged battery, it fired up and everything worked fine, I had OD, the battery was being charged, the speedo was working and the OD button light was on. Then after 5 minutes of driving I lost OD again, the speedo went flat, etc. etc.
I unscrewed the speedo cable at the tailshaft and taped the rounded off shaft and slid it back in, went for a test drive…no improvement.
I put the TPS back on…no improvement.
I stared into the engine bay for 15 minutes and whispered sweet nothings ...no improvement.
Next steps, remove the taped speedo sensor and replace with a new one. Check the voltage with the bad TPS on (will this really matter?).
Any recommendations?
jrussell: old post, I'm sure you've fixed but...the gurus always said "check your grounds..." I had same symptoms and thought, "no way grounds could be responsible for all this."
Yup.
There's ground screws on both fenders. Take off and sand to bare metal, including wire ends, spray with electrical spray (dont use silicon - it forms a barrier that significantly resists low volt/amp signals like with the pcm (see audi engineers comments below post).
Any splices? I had one. Turns out this was my culprit. Bypassed with new wire to clean fender contact/bolt and instruments popped back on...but not before spending bucks on a new Speed Sensor...
- Regards,
Shawn Beightol
1995 Dodge Ram 2500 Diesel
stock everything
bought the truck at 185k miles, just turned 420k
Audi Engineer's comments on wire contacts:
"Sometimes a poor connection is actually caused by a well meaning person trying to help the problem by using cleaning sprays that contain silicones to make the connections water-repellent. Why is this harmful? This is because silicone when certain conditions exist, can combine with metal ions to form high resistive films such as sodium silicate.
Those of you who have replaced a full throttle switch on a 200 or 5000 turbo engine know that even though the contacts are physically touching no signal gets through the switch.
This highlights that it is more difficult to design a connector to carry a small signal than to carry large current. Contaminant films which would be of little problem for higher current flow will cause conditions in low signal current ranging from zero-crossing distortion to an intermittent connector..."
