Stripped bell housing bolt hole
Old Oct 20, 2020 | 08:35 PM
mopar2ya's Avatar
Rebuilt my Getrag and during install one of the trans to bellhousing bolt holes is stripped. Tried a bit longer bolt, still nothing. Anyone tried to use a m14 bolt in one of those holes? Im just not ready to pull it all out again and am looking for a work around..
Old Oct 21, 2020 | 04:45 AM
KRB's Avatar
KRB
Helicoil?
Old Oct 21, 2020 | 07:17 AM
mopar2ya's Avatar
Originally Posted by KRB
Helicoil?
Not without pulling everything back out. Im hoping to avoid that until I need to do a clutch down the road.
Old Oct 21, 2020 | 08:22 AM
Just an FYI Getrag bell housings come with two different bolt hole sizes. The bigger holed housing will take the smaller bolt, if you are not paying attention, but I could see it loosing up over time, or ruining the threads.
This might not be what is going on in your case, but worth noting.
I just happened to catch it on a build years ago. I pulled out 6 Getrag bell housings I had on the shop shelf and found out 1/2 took a larger diameter bolt than the other 1/2 of them. Now I always pay extra attention on re-assembly.
Old Oct 21, 2020 | 06:36 PM
mopar2ya's Avatar
These are the same 1/2x13 bolts that came out. I modified a 14mm bolt and will see if theres enough thread left for it to tighten up tomorrow.
Old Oct 22, 2020 | 05:54 PM
mopar2ya's Avatar
So I took a 14mm bolt and angle ground the tip down and lightly tapered the threads back to the shoulder of the bolt. Then took a triangle files and resharpened the threads. I also cross cut the end to act as a reamer as it went in. Put anti-seize on it and it went it pretty nice. The deeper it went in the tighter it got due to the taper on the bolt. Should be fine until I can fix it next time I pull the trans...
sdseva
Jul 11, 2010 07:16 PM
aborgardt
Aug 7, 2009 03:28 PM
Racing_Joe66
Nov 27, 2006 09:10 PM
Underpsi
Jun 16, 2006 02:46 PM
StrokeThis2500
Feb 17, 2006 07:03 PM
