starting problem
Old Jun 1, 2009 | 10:23 PM
ol' 93 12 valve's Avatar
starting problem
i did a nv4500 swap into my 91.5 auto, i cant get it to start. I jumped all the connectors that were plugged into the auto that are now just laying under the hood, My question is what do i do to get it to bypass the neutral saftey switch so i can start it with the key. I dont care if it is a toggle switch that i have to flip.
Thanks
Old Jun 1, 2009 | 10:57 PM
BigIron70's Avatar
Cummins Guru
The wire just grounds through the neutral start switch, one wire is for backup lights power 12Volts the other goes to backup lights. The 3rd wire is gound for start relay. Not sure on wire colors but test light can locate the power wire, just don't ground that one or you will blow fuse. Wiring from 97 but should give you the basic idea how it's wired.
Old Jun 2, 2009 | 10:23 AM
apwatson50's Avatar
Will it turn over but not start, or will it not engage the starter?
Old Jun 2, 2009 | 11:45 AM
big stinky's Avatar
Still got the twisty thing on the column? If so, make sure its in park position. Or neutral for that matter. Its still attached to the linkage?
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
Palmetto_kid
Apr 25, 2003 05:14 PM
turbospl311
15
Jan 21, 2003 12:39 PM
