starter problem with 618 conversion
Old Apr 17, 2008 | 11:55 PM
mullishacrew's Avatar
alright well i got the starter put in and i see that my starter will only nick the tip of the flexplate gear tooth, i can only put the starter in one way and i cant figure out how to get it to work, if i turn it one way the start bolt flange hits the block and there is really no way i can turn it the other way because the start body will hit the block on the bottom, what would you suggest? i also put the 618 adapter plate with tourque converter and flexplate in there and im using my old starter from the 518, is there something im supposed to modify? i see in the sticky it says i can use the old starter.
Gregg
Old Apr 17, 2008 | 11:59 PM
oooooops, well i read that again and i see i need a new starter, sorryy about makin ya read that.
mullishacrew
Jun 7, 2009 01:21 PM
mullishacrew
Apr 27, 2008 04:54 PM
mullishacrew
Mar 30, 2008 05:20 PM
amdderik
Mar 15, 2007 11:03 AM
furious70
Apr 21, 2003 08:52 AM
