Where to get governor weights for 618 swap
I have been searching around trying to find the governor weight kit for the 618. Apparentally Dodge stopped making the kit and the dealer can't get the kit either!
I have called a bunch of different transmission parts shops and nothing.
Where are you guys getting this weight kit?
Thanks,
Derik Harris
Thanks,
Derik Harris
Call these guys Transmission Parts USA 239-790-5401 I don't see the gov listed but they might be able to get you one. If they don't have it you will have to go to a wrecking yard and dig through the trans core bins for a while. Is yours bad or just trying to change the way it shifts? or do you have to change it to do the swap.
. The v-10 makes about 450 ft lbs @ 2500 so I would think that it should be OK. It is a lockup converter too right? you will need some other stuff to make it work right.
Ya, there is a ton of info for this swap on this website, it is awesome.
I need the 3 pin connector and some switches for the wires that come off of the connector to control the lockup TC and overdrive override.
Try calling Dave Goerend. He should be able to help you out.
http://www.gbtransmissions.com/
Dave came through for me, he had both of the weights.
I just removed the old trans and I am getting ready to put the new 47RH in now, but I have a problem.
I have a 2 wd 47RH from a V-10, it looks like I am missing an adapter housing that connects the transfer case to the transmission... do I need an adapter housing from a 94-95 47RH 4x4 to connect this transmission up to the NP 205?
Thanks for all of the help!
You need to swap the overdrive sections, there is no adaptor, theres a 2wd and a 4x4 overdrive section.
I talked to Dave about using the OD section from my A518 and mating it to a 47RE I have in the shop, then use a 47RH valve body to make a 47RH. He indicated it should bolt right up.
Take the OD section off your A518 and the OD off the 47RH and compare them. You won't need governer weights now because you are going to use your A518 overdrive section now. I would have it rebuilt if you have any kind of miles on your A518.
I'll give you guys an update. After calling a ton of junk yards all of the relied the same, "We don't tear apart our transmissions for parts!" After calling only a few transmission shops I found one that had the parts that I was looking for, so this weekend she should be running down the road.
Thanks for all of the help.
