Stainless Brake Hoses
Old Sep 28, 2014 | 10:14 PM
schamran's Avatar
Has anyone had any luck finding stainless lines recently? All I can find for the banjo fittings are the round style fittings, like the ones on the bottom of this pic. I am keep imagining them loosening up after a few lock-to-lock turns. The edges of the "block" style fitting engage the caliper, so it isn't allowed to work the banjo bolt loose. Thoughts?
http://www.fulltiltstreetrods.com/brakelines-cu2.jpg
Old Sep 29, 2014 | 05:33 PM
u2slow's Avatar
Stock brake hoses are good enough for me. Even when I need longer ones, I just change the mounting location.
Old Sep 29, 2014 | 06:09 PM
carrnutt's Avatar
You might want to try a hydraulic hose maker. They may be able to re-use the stock ones or have / can get the ones you need / want.
When I converted my 69 Charger to discs, I got custom lines made for about the same cost as stock lines from auto parts store at my local http://www.hosemakersplus.com/.
Old Sep 30, 2014 | 08:13 PM
BearKiller's Avatar
I would try the brake hose division of Classic Tube, the people who make the direct replacement stainless brake-lines for classic cars and trucks.
I can't recall the name their braided stainless hose division goes by, but they are always advertised on the same page of magazines as Classic Tube and are the same people.
I needed custom braided stainless hoses for my F-350; I called them, gave them the lengths I needed, told them the particulars about the truck, and had them in hand in about a week.
When I first installed the braided hoses, I could definitely tell a difference in braking response; no soft hose to swell up before the brakes applied.
If nothing else, you might talk them into taking the hardware from a new set of O.E.M. rubber hoses and attaching the braided stainless to that; that may very well be what they are doing anyway.
Old Oct 1, 2014 | 08:33 AM
BarryG's Avatar
you could also try EGR Brakes the pictures show the block style
http://www.egrbrakes.com/brakelinekit.htm
Old Oct 1, 2014 | 08:55 AM
mknittle's Avatar
I am piecing mine together from parts from Summit racing.
Much cheaper than the " kits"
BC847
Sep 2, 2014 10:31 PM
PRO-NRA
0
Jan 2, 2010 03:36 PM
oldblues
May 16, 2007 03:55 PM
01350banshee
Apr 17, 2006 08:49 AM
