Stacks and 16cm installed
Old Aug 11, 2008 | 08:52 AM
XCLR8N's Avatar
I just got my dual 5" stacks and 16cm housing installed in the truck. Man what a difference that little bit makes. I haven't touched any of the tweaks or pumps yet, but that make a tremendous difference over stock. I should have some pics posted later today. While I was under the hood I also tapped the hole for my pyro and installed the probe but havent hooked up the gauges yet so I will probably get to that this weekend.
Old Aug 11, 2008 | 09:22 AM
jcmoyer2004's Avatar
how tall are your stacks and how loud is it in the cab
Old Aug 11, 2008 | 09:39 AM
XCLR8N's Avatar
I should also note that I installed the Rip Rook's 4" downpipe and a 4" muffler. Inside the cab is not too bad at all unless you have the windows open, due to the close proximity of the stacks to your head and ears. The stack I would say are about 4 ft tall. They stick up over the cab about a foot. I went from a stock exhuast that was cut off just aft of the cab, so it made a huge difference to me. The cab does have a little more vibration then before but nothing you cant live with.
Old Aug 11, 2008 | 09:46 AM
oh ok, well i was thinking about putting a set on my regular cab, but don't like them to be that high above the cab and i didn't want to run a muffler on it, so i think it would probably be a bit too loud for me in the cab with the windows up.
Old Aug 11, 2008 | 09:53 AM
XCLR8N's Avatar
Only reason I put a muffler on it was because I live in an older community and wanted to take a little bite off it. I can see straight through the muffler so it is more of a resonator than muffler. I will post pictures up later so you can see exactly how it looks. I think you would really like it.
Old Aug 12, 2008 | 08:52 AM
XCLR8N's Avatar
I took the pics but forgot to post and I am at work, so when I get home tonight I will post them up.
Old Aug 12, 2008 | 01:45 PM
Mattster's Avatar
Older Community? You must be from Gig Harbor.
Old Aug 12, 2008 | 02:02 PM
Ezra's Avatar
Sounds like a cool setup......
Ha ha all that means is your both from the wrong side of the mountains.
Old Aug 12, 2008 | 02:05 PM
Mattster's Avatar
I've been trying to get a job over in Spokane with the rail companies but no luck. I like it over here but people are more friendly over there.
Old Aug 12, 2008 | 02:14 PM
Ezra's Avatar
yep.alot more real people on this side..not so many liberals and limpwrist.
Old Aug 13, 2008 | 10:53 PM
XCLR8N's Avatar
Nope, i live in Silverdale.
I live in a townhouse division, with a lot of older folks in it, so I try to be mindful but at 5am its hard to do anything quiet.
Without further ado:
Attached Thumbnails Stacks and 16cm installed-dsc02373.jpg   Stacks and 16cm installed-dtr1.jpg   Stacks and 16cm installed-dtr2.jpg   Stacks and 16cm installed-dtr3.jpg   Stacks and 16cm installed-dtr4.jpg
Old Aug 13, 2008 | 11:26 PM
SmokemS's Avatar
looks good but the left stack needs to be bumped(turn) alil to the left
Old Aug 13, 2008 | 11:30 PM
Mattster's Avatar
Looks good just need to make adjustments to the left one as mentioned. Bet it sounds great. I really like the sound of my 4" straight pipe but have been thinking about stacks.
Old Aug 13, 2008 | 11:48 PM
whereswaldo250's Avatar
I just got my 4" exhaust but I love stacks. Looking Good!
Old Aug 14, 2008 | 07:24 AM
chuck'64's Avatar
I am going to be installing a single stack on my truck does any body have pictures of the under bed routing for the pipe?
thanks and nice truck!!!!
