Speedometer attachment/Overdrive correlation?
Old Jun 27, 2016 | 11:42 PM
BULLS-N-BRONCS's Avatar
My speedometer attachment at the trans case grenaded on the way to work this morning. On the drive home I found that O/D is now non functioning. Is there a direct correlation to the speedo going south? What is the actual correct name for the speedo attachment? Any thoughts and help would be greatly appreciated.
Old Jun 27, 2016 | 11:43 PM
Forgot to say, 91.5 intercooled W250
Old Jun 28, 2016 | 12:35 AM
Angry Johnny's Avatar
What exactly came apart? That is the vehicle speed sensor there but there is also the adapter and pinion gear there too. The PCM needs to know the vehicle is travelling at least 32 MPH before it will allow O/D.
Old Jun 29, 2016 | 12:11 AM
I believe it is the speed sensor still attached to the transfer case. The adapter where the wiring plugs in is gone.
Old Jun 29, 2016 | 06:00 AM
Thanks Angry Johnny, I didn't now the particulars on the sensor.
Oliver has a few of them lying around. I nearly lost mine as well. It loosened up, but I caught it in time before it fell out....
Surprised the wire didn't keep it attached to the truck..
(dangling)
Old Jun 29, 2016 | 10:14 AM
The sensor has a large nut that screws onto the adapter that holds the pinion gear. Get you a new sensor and connector. Should be all you need.
Rick 12v CTD
Dec 12, 2012 10:14 PM
hungabunga
May 7, 2008 09:15 AM
carl20320
Feb 25, 2004 10:45 AM
matthopp
Feb 20, 2004 10:16 AM
Lon
Jan 25, 2003 06:56 PM
