speedo/odometer
Old Apr 3, 2012 | 06:12 PM
jmadisonw250's Avatar
Question speedo/odometer
About a month ago my odometer quit so I finaly got around to doing it. I got it done and put all back together and now my speedo or odometer dont work so I took it off and made sure the teeth were lined up seemed to be I rotated the gears and everything turned just fine still didnt work.
So I pulled it back out and used some air to blow it out and still didnt work and one last thing my over drive dont work eather now it was iffy before but up at speed it would stay in I plan on doing to pot upgrade some time. any help would be appreciated
Old Apr 3, 2012 | 07:37 PM
Onemoparnut's Avatar
Check and clean the connection to the vss on the trans. If there is no speedo signal there will be no od. Might not be related to what you did to the speedo at all.
Old Apr 3, 2012 | 08:41 PM
alright thank you ill try that tomorrow
Old Jun 21, 2012 | 09:28 PM
Exekiel69's Avatar
How much voltage should I get at the TC sensor? Can I just give it 12v through a relay when the engine is running in case it isn't getting any?
Thanks.
Old Jun 21, 2012 | 09:50 PM
mopar2ya's Avatar
What is that deal the speed sensor bolts into on the transfer case??
fire1861
Jan 6, 2006 11:37 PM
Chrisreyn
Oct 2, 2005 01:02 PM
blackcloud
Jul 20, 2005 09:52 PM
BA05'CTD
Mar 3, 2005 10:36 PM
