Speedo floats
Old Aug 26, 2006 | 11:10 AM
RATCHET's Avatar
Speedo floats
Started a couple of weeks ago, under power the speedo is accurate, but let off the throttle and it drops about 20 mph. If i push the clutch in it reads within a couple of mph of the under power reading. Seems that the biggest drop is only when decelerating without touching the clutch. Does the speedo gear in the transmission slip if the yoke is loose?
-RATCHET-
Old Aug 26, 2006 | 02:56 PM
flashgordon's Avatar
-RATCHET-
I think i would start with making shore the speedo gear,adaper(if used on your truck) and speedo cable tip isn't rounded off!
Old Aug 26, 2006 | 03:02 PM
Lightweight's Avatar
Check the bolt that holds the slip yoke on the out put shaft of the transmission, if it is still a Getrag. If this bolt is loose your gear will slip and speedo will read wrong. Also cruise control will bounce, jerk, well you know .
GW
Old Sep 1, 2006 | 03:23 PM
RATCHET's Avatar
Checked nut on transmission yoke today. It was flopping around in the yoke. New seal, new fluid and speedo is back to normal.
-RATCHET-
TJE
Mar 9, 2011 06:48 PM
getblown5.9
Feb 4, 2006 04:17 PM
Monty
Feb 9, 2003 05:07 PM
chdiesel
Oct 31, 2002 03:22 PM
