Someone fill me in or link me to a breakdown of the various turbos?
Old Mar 10, 2010 | 09:10 AM
Subliminal's Avatar
Hey folks,
I have a 91.5 W250...I hear she's got the lagmaster turbo setup.
I'm wondering if there's a site that breaks down which turbos came on which trucks and which ones are good for what goals, etc...
I can see myself wanting some more performance in the future, but would like to know, say, if it'd be better to get a different turbo or to just replace the exhaust housing.
Anyway...thanks!
Old Mar 10, 2010 | 01:17 PM
92smokin blacky's Avatar
I think Holset.com has the map efficiency of Holset turboes if i remember right.
Old Mar 10, 2010 | 03:37 PM
Astro's Avatar
Your 91.5 most likely has a H1C with a 21cm2 turbine housing housing. Very laggy. Going to a smaller turbine housing like an 18 or 16 would be a quick upgrade that won't get the EGT's too hot and it'll spool quicker. Running a 12cm2 housing on a H1C will spool very fast, but will get hot quick because it doesn't push enough air. If you can find the 14cm2 turbine housing (they didn't come on Dodges, I forgot what they came from) they spool much quicker, but are large enough that you won't reach piston-melting exhaust gas temperatures the second you put your foot into it.
The first real upgrade I did when I had my ol '92 (RIP) was put a stock 2nd gen HX35 turbo with a 14cm2 turbine housing (they came with 12cm2 stock, but I had a 14 laying around). The downpipe flange was different than stock, but I made a new piece to adapt it. The rest of it bolts up. Made a huge difference in the truck's power and never ran hot EGT's. Eventually the truck got injectors, fuel pin, pump tweaks, and the turbo was upgraded further.
Here's the link you're looking for...
http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
Old Mar 10, 2010 | 04:47 PM
bariley's Avatar
Originally Posted by Astro
Y If you can find the 14cm2 turbine housing (they didn't come on Dodges, I forgot what they came from)
busses ring a bell... someone correct me if im wrong
dditt0635004x4
13
Feb 7, 2007 12:36 PM
Cummins4Life
Jan 9, 2005 01:34 PM
bcb1962
Jun 24, 2003 10:16 PM
1320
30
May 31, 2003 01:01 AM
