So I put me a boost gauge in today...
Well guys, tell me what you think. I put a boost gauge in today. Holding it at wide open throttle pulling a pretty steep grade I hit 30 psi. The gauge is a genuine Peterbuilt Manifold Pressure gauge out of a 1979 Peterbuilt. The gauge was bought new a couple years ago so I am pretty sure it is right on. Is that typical of the 1st. Gen Cummins? Read my sig. I am bone stock except for the fuel being turned up about 20% and I have drilled out my stock air box with 9/16" holes all through it.
Mine is turned up a bit more, but I believe my timing to be stock. I have seen 38 psi with it. The way I have it tuned now, I get about 34 psi backing out of it at about 1300 degrees with the hot needle still climbing. So, I wouldn't say it is high for what you have.
-Steve
-Steve
Depends on the size of the exhaust housing, but since the H1C and HX35 have smaller wheels than the 40, they should spool faster.
You'll probably lose 1-2 mpg with the 12cm housing, especially since you'd be running higher RPM's with the 3spd auto. Also, on an auto the smaller housing doesn't make as much of a difference as on a manual truck.
If I were you, I'd at least get a pyrometer. It's useful for keeping the pistons from melting, and it can be used to diagnose problems as well. It's money well spent.
Plus, it's fun to watch.
