So I Got Mad and Broke a Window in the Truck...
It's kinda funny how things work. I read this post last night and was thinking that luckily this hasn't happened to me in a while. THEN this morning on my way to El Paso, I stopped for some fuel for myself and the truck. With the truck still running I accidentally locked the door. Luckily I keep a set of wrenches around! I had to take the headache rack off of my truck, take my pocket knife and open the sliding back glass. As I am a pretty large man(6'2" 275 lbs) I had to pay some kid $5 to crawl through and let me in. What happened to kids doing something just because it was fun. Now they wanna get paid(Must be the economy)
On an 02-08 pull top of door (front passenger) out and keep it out with a block of wood (about 5/8 inch). Lower a coat hanger with a thin wire loop over the ***. Crank the hanger around until the thin wire tightens on the **** and then pull up. When you open the door be prepared for the alarm.
I'm up to twice. $45 for the first mistake. That taught me how to do the second. A broken slider is $1300 (dog jumped through it). What is a spare key worth? If I am not driving - the key is in my pocket. I once had a passenger lock the keys in the rig and had to ride the horses in the trailer 25 miles for a spare.
Ah well, that's why god made insurance companies... except alot of policies have an exclusion now for when an insured hits one of their own vehicles...
I got the new window, put it on, it doesn't fit well so its gonna leak. And the guy at the junk yard must not know how to read tint codes, he told me it was my tint code and its not - I can hardly tell its even tinted. So on top of that, it looks like crap. I am literally thinking about welding sheet metal over them and deleting the windows.
if you have a topper that you can lock you could hide a key for that and leave the rear window un latched,
that way if someone found the key it wouldn't work in the ingnition and most would not think the rear window would be unlocked
Now you have a reason to tint your widows
. Did you have the junk yard install it? Just clean out the frame w/ a razor blade and flat head screwdriver, glue the glass in using a 2 part epoxy, or windshield urethane. I used to install auto glass back in the day. I have so many scares from that job.
. Did you have the junk yard install it? Just clean out the frame w/ a razor blade and flat head screwdriver, glue the glass in using a 2 part epoxy, or windshield urethane. I used to install auto glass back in the day. I have so many scares from that job.No, I installed it myself. I bought the whole window, not just the glass. A couple of the little window mounting hole things are stripped out from when the previous owner apparently replaced the window once before.
I locked my keys in my truck while it was RUNNING!
lol. I was at farm and fleet to buy a battery for it after I had it jump-started, and left the ignition key in the truck, and took the door key with me. (had to replace ignition after 4XX,XXX miles
) The guy told me it was an 825 amp battery, and I knew he was wrong, so I went back outside to look at my owner's manual. Opened the door, threw the keys on the seat, grabbed the manual, shut the door.
So I started with a coat hanger, and it started to rain. So I started kicking one of the small panes on my back window, but it wouldn't break.
Finally I turned around, facing the tailgate, and gave it everything I had with my heel. It fell out of the rubber and landed on my seat!
It was a great excuse to take it all apart and fix my leaks too!
I find that it is VERY easy to break into non power window trucks. You can use both hooks from a bungee cord. Bend to the correct fitment and use one hook to depress the locking button on the wing vent window and use the other (or another stick like object) to lift the latch. Viola the rest is cake, stick your arm in and unroll the window.
From: anderson commiefornia oh ya you can keep the "change"
After being locked out of my car once, I went to a two key ring system. I have my house keys and keys to all the vehicles on one key ring (along with a small adjustable wrench, a multi-tool, and a really bright little flashlight, but that's another story). That key ring stays in my pocket except to lock the house or if I need one of the tools. Each vehicle is driven using a key ring that has only the keys to that vehicle. If I lock the keys in the truck, no big deal. I just pull my main key ring out of my pocket and open the door.
Has saved my butt a couple times.
Has saved my butt a couple times.Knock on wood
or the old Indian trick 2 Allan wrenches (L tipe) 2 vice grips or pliers slip them under wing window turn 1 up to hold the button in use the other to flip up the latch on Ur wing window
after i called the locksmith to let me in for 75$
and he has 2 pieces of metal just like the Allen wench only with handles i thought ha i could find something like that and i did
people that
CHARGE
others to unlock there car should be shot that should be a crime hey where all human we make MISTAKES
Oh and i just discovered this
what the hell???where did this come from
good god
