Slanting Driver side tire
Old Oct 31, 2012 | 12:57 PM
1_buck_truck's Avatar
Exclamation Slanting Driver side tire
Hey yall my driver side tire is starting to slant pretty bad and when drving i get a pulsating noise coming from the front like a. woom woom woom woom lol picks up pace with speed. any ideas how to stop noise and get tire straight again? also my streeing wheel has tons of play. Ideas? thanks Guys and Gals good to be back!!
Old Oct 31, 2012 | 01:17 PM
peckens's Avatar
You need to replace your steering shaft as the factory one is crap and probably rotted out.
http://ramchargercentral.com/index.p...iew;article=96
Old Oct 31, 2012 | 01:27 PM
gyman98's Avatar
Sounds like a wheel bearing, they make that noise
Old Oct 31, 2012 | 01:46 PM
Alright i will replace the steering shaft no problem that will get rid off the slop in the steering wheel so what about the slanting wheel? any ideas??
Old Oct 31, 2012 | 01:51 PM
gyman98's Avatar
Wheel bearing or king pin problem
Old Oct 31, 2012 | 02:57 PM
BILTIT's Avatar
Since your sig. shows a 2wd than its a wheel bearing problem most likely, could be a ball joint.
Old Oct 31, 2012 | 03:37 PM
Sig is messed up the truck is a W250 did it on my phone and messed up
should change it now though! haha
Old Oct 31, 2012 | 04:33 PM
BILTIT's Avatar
Then it could be a kingpin issue but most likely a wheel bearing.
Old Oct 31, 2012 | 04:34 PM
j_martin's Avatar
If it's a wheel bearing and it's that bad, you're in imminent danger of being a 3 wheeler.
Good luck with that!
Old Oct 31, 2012 | 08:26 PM
deanhinsley1963's Avatar
x2 wheel bearing or king pin wear.
Old Nov 1, 2012 | 05:12 AM
KRB's Avatar
KRB
Hope you are not driving it until you get that fixed right?
Old Nov 1, 2012 | 10:14 AM
She is in the garage i dont have a death wish ahaha buying the wheel bearing tonight and replacing it. and Steering shaft
Old Nov 1, 2012 | 05:55 PM
longshotranch's Avatar
make sure you put new races in with the new bearing
trik396
Aug 19, 2006 01:18 AM
guyssets
Sep 24, 2005 02:13 PM
Gordonville
Aug 13, 2004 11:07 AM
popeye
13
Jan 13, 2004 11:54 AM
atc250r
Aug 26, 2003 08:52 PM
