skyjacker lift instalation
Those of you that are using the skyjacker springs on your truck, did you install them or did you have someone else do it. If you had someone install how much did it cost.
Thanks,
Jim
Thanks,
Jim
Re:skyjacker lift instalation
u doing front or rear? on my 93 it was wrecked and the front springs where bent so i had to replace them it was very easy jacked truck up unbolted everything roled axle out from under truck and took springs off and put new ones on roled back under truck and hooked everything up!! had to do it twice cause i purchased the wrong springs the first time whoopppppssss
but it was very easy. few hours and air tools!! and if its the rear i put 8 inch skyjacker lift on my 83 dodge that was about 1hr job! tough part was trying to get the bolts out very rusty!!! do it urself and save money for more bombs!! ;D
Looking to do both front and rear at the same time if wallet permits. So little time so many bombs to do to the truck and limited money, i guess I will keep buying the lotto tickets.
I put a 2.5 lift in my truck last month took about 2 hours start to finnish in my driveway. Job was very easy and the springs and bushings fit perfectly. If you are going higher you will need to change a few things, might make the job a little harder. If you don't mind me asking how much did you pay for the springs?
Paws
Paws
RoadDawg
Apr 10, 2005 10:26 PM
Turbo Deeezle
Jun 20, 2004 04:13 PM
pappygtb
Apr 7, 2003 12:42 PM
