Shift light
Old Mar 2, 2012 | 10:40 PM
Onemoparnut's Avatar
Shift light
Is it possible to put a shift light in my truck? I don't know exactly how they work but is it possible?
Old Mar 2, 2012 | 10:51 PM
dB Zac's Avatar
Yes. Some will say no because some have not been able to get auto meter or other brands to work but I had an auto meter that worked on the 4 cylinder setting
Old Mar 2, 2012 | 11:08 PM
Were you using the auto meter tach with a shift light? I would like to keep my isspro tach and just add a shift light. I read somewhere that isspro is making a tach with a built in shift light but I cannot find it on their website.
Old Mar 2, 2012 | 11:24 PM
dB Zac's Avatar
I just had the tach. But where the tach, so well the light
Sent from my Galaxy Nexus using Tapatalk
Old Mar 3, 2012 | 03:14 PM
crazy clem's Avatar
my msd shift light is hooked to tach signal wire tach was installed by po the thing about the msd light it works off chips not that accurate not on the truck anymore
Old Mar 3, 2012 | 09:36 PM
schamran's Avatar
Why do you want a shift light?
Old Mar 3, 2012 | 09:56 PM
Cause the tach is hard to read at night the light is a little dim. Also that 1-2 shift comes fast when you are beating on it. By the time I move my eyes from the tree down to the tach I almost missed the shift already.
Old Mar 3, 2012 | 10:14 PM
BILTIT's Avatar
Why use 1st? I only use 1st gear when hauling.
Old Mar 3, 2012 | 10:33 PM
It applies the low band in the trans which does not apply when the shorter is in drive. Makes the trans a little stronger is what I am thinking. Also I am having some trouble getting the shift points perfect so I can just leave it in drive.
Old Mar 3, 2012 | 11:14 PM
92smokin blacky's Avatar
do my "zip tie mod"
zip tie the TV cable open and adjust to your liking and when you want the shift points. I had my trans shifting at 2700rpm+ this summer while pulling and racing
Old Mar 4, 2012 | 01:23 AM
BILTIT's Avatar
Ah an auto, my bad.
Old Mar 4, 2012 | 06:17 PM
deanhinsley1963's Avatar
I think MSD makes a stand alone shift light you would have to put the magnet on the crank to trigger it though.
Old Mar 4, 2012 | 06:21 PM
I will check that out thanks.
Old Mar 4, 2012 | 06:26 PM
No problem summit should have them.
Old Mar 4, 2012 | 07:03 PM
Looks like they hook up to the coil or msd. Plus they only go down to 3000 rpm. Thanks for the info anyway I am going to call isspro tomorrow and see what they say. I see a few posts on other diesel sites about isspro making a tach with a shift light but I can't find it on isspros website.
