Security torx screw driver
Old Jun 27, 2013 | 05:17 PM
simplysmn's Avatar
Where can you get a torx driver that is able to remove the bolt's For the Ign switch on a 92-93 ? Tilt Column Any Idea's I bought torx driver's and realized I need the other 1's
Old Jun 27, 2013 | 05:24 PM
rrgrassi's Avatar
I bought a set of them at Harbor Freight.
Old Jun 27, 2013 | 05:25 PM
simplysmn's Avatar
That's where I got the set I have now but didn't realize I needed security bit's O well you can Never have enough tool's .
Old Jun 27, 2013 | 05:28 PM
rrgrassi's Avatar
It came in a box of bits along with screwdriver bits, hex head bits, etc. I agree, you can never have too many tools!
Old Jun 27, 2013 | 05:30 PM
cougar's Avatar
Sears is were I got mine. You need the one with the little hole in the end.
Old Jun 27, 2013 | 07:19 PM
j_martin's Avatar
Harbor freight has a little ten buck security bit set that has about everything in it, torx, hex, tri-wing, etc. I don't leave home without it.
Old Jun 27, 2013 | 08:51 PM
simplysmn's Avatar
Good to Know Thank You Sir .
Old Jun 27, 2013 | 09:54 PM
93flatbed's Avatar
Snapon has them also.
Old Jun 28, 2013 | 05:20 AM
KRB's Avatar
KRB
Not very "secure" if you can buy them anywhere huh?
Old Jun 28, 2013 | 07:29 AM
sooty's Avatar
all the auto parts places can order them, if not stocked, I hate , special tooling, so another option, some locks have a bolt that tightens and breaks off with no tool provision, I use a disc grinder or hack saw blade to make a slot, then use the impact screwdriver to loosen and remove
Old Jun 28, 2013 | 02:53 PM
Jim Lane's Avatar
I was just going to say, be lucky you are not working on a Porsche BMW or Mercedes they use a lot of shear head bolts on the dash and ignition components.
But although they appear to be a blank round head they are really slightly oval and have a driver to remove them.
The security drivers I use on the switch and bottom cover are by Picque, you need a long bit to remove the bottom cover.
http://www.frys.com/product/4922491
But do not pay over $10.00 for them,
New egg is ripping people off for $62.00.
I will post some pictures later.
BTW you did not used to be able to get them anywhere, only fastener specialty shops and they took your name and license number first, try working on motorcraft AVS carbs without them.
Jim
Old Jun 28, 2013 | 03:08 PM
93flatbed's Avatar
GM has been starting to use the shear head bolts. I'm a freaking ningia with a air hammer and a 12" chisel bit. Customers don't seem so enthusiastic about seeing me do it, but hey I have yet to let it get away from me to destroy a cluster.
The real scary one is using the air hammer to knock the riviots out of window glass that is attaching the regulator...
Old Jun 29, 2013 | 05:29 PM
simplysmn's Avatar
Yeah bought a set today at harbor freight 6 buck's out the door atleast now I have them didn't realize how easy it would be to drop Ign switch out of a first gen Sweet.
Old Jul 1, 2013 | 05:03 PM
Bob L's Avatar
Do you have the SKU or item number by chance ?.
I'm going to get a set at HF and the item number would be handy.
Thanks,
Bob
Old Jul 1, 2013 | 05:31 PM
simplysmn's Avatar
HEY Bob they come in a red plastic holder with a bit extention in middle in our HF it was close to bottom of rack you Can't miss them .
