running problem
Old Oct 22, 2011 | 01:32 PM
td3620's Avatar
Question running problem
my buddy has a 93 dodge diesel daully.its getting air in lines somewhere. when you bleed injectors it will start right up.drive all day then when you park it.then go back out about 1 hr later it want start.i think the (lift pump) is out.seeing what yall think.thanks
Old Oct 22, 2011 | 01:36 PM
Onemoparnut's Avatar
Does the engine oil smell like fuel? You can also use a rag and a blowgun in the filler neck and try to pressurize the fuel system. Then look for leaks in the fuel system.
Old Oct 23, 2011 | 10:21 AM
td3620's Avatar
no fuel in oil.
Old Oct 23, 2011 | 10:25 AM
Then you are going to need to get the system under pressure and look for leaks. It won't take much pressure to see where the problem is.
Old Oct 23, 2011 | 07:59 PM
td3620's Avatar
thank you very much
Old Oct 23, 2011 | 09:13 PM
No problem did you find the problem yet?
Old Oct 23, 2011 | 11:22 PM
td3620's Avatar
i havnt got a chance to do it yet.got to wash it all of the dirt off
black&blue
Feb 18, 2009 08:32 PM
smokey196240
May 27, 2006 08:44 AM
moparsupremist
Aug 22, 2005 12:06 AM
bdog
Apr 6, 2005 08:30 AM
Sir Kaos
Mar 22, 2003 11:01 AM
