Running lights
Old May 18, 2015 | 09:16 PM
lockgessner's Avatar
Running lights
Anyone know where to get replacement running light inserts( just the Orange lens) for our trucks.. Mine are cracked and look bad
Old May 18, 2015 | 10:18 PM
edwinsmith's Avatar
You would need to let us know what year your truck is. Try J.C.Whitney or Rock Auto.
Old May 19, 2015 | 08:05 AM
mknittle's Avatar
These?
Truck Parts and Truck Accessories
Old May 19, 2015 | 01:13 PM
It's a 93; I guess I should have specified the roof lights. It's good to know LLC has the side markers now!
Old May 19, 2015 | 01:46 PM
j_martin's Avatar
Different lights have different names.
The bright square ones are headlights
The yellow ones near the bumper are front marker lights
The red ones in the back beside the tail gate are tail lights, or rear marker lights
The two outside lights on the roof and the two outside lights on the tail gate are called clearance lamps (Shows how wide is the vehicle)
The three in the middle on top, and the three in the middle on the tail gate are called identification lamps (indicates a wide vehicle)
The two lamps on each rear fender are called side marker lights.
Clearance, side marker, and ID lamps are required on a 1T or larger truck.
All of this is federal requirements.
The marker, clearance, id and tail lights collectively are called parking lights. (on a pickup)
Old May 19, 2015 | 04:41 PM
james1's Avatar
If I'm not mistaken, Mopar refers to the yellow plastic covers as "stone shields" and the OEM part number is: 3738 011. You could phone the parts desk at your local Dodge dealer to see if those are still available.
Also note that Hella once manufactured chrome colored replacements. The Hella part number was 79726 but they are now long out of production .
Several years ago I cracked all five of mine by running 168 bulbs instead of the lower wattage (and cooler) 194's. I now run LEDs, which are much cooler than any incandescent bulb.
Old May 19, 2015 | 05:36 PM
mknittle's Avatar
Something weird happened that wasn't the page I tried to link to
Old May 22, 2015 | 03:18 PM
Thanks guys, james1 I contacted the dealer today and they can get them. 20$ each
Old May 25, 2015 | 08:45 AM
ofelas's Avatar
'89-'93 Dodge Ram OEM Cab Light Lense-Geno's Garage
Old May 25, 2015 | 01:56 PM
jimbo486's Avatar
I could be mistaken but, I thought DOT regulations said that any vehicle 80" or wider is required to have clearance and identification lights.
Old May 25, 2015 | 04:29 PM
j_martin's Avatar
That could be. I think the duals are what takes it over the line, and that's probably DOT's intention.
Old May 25, 2015 | 06:10 PM
jimbo486's Avatar
More than likely the case. I seem to recall a dimension around 92" measuring from outer sidewalls on my truck. The fenders poke out another 1" or so beyond the tire.
Old May 25, 2015 | 09:30 PM
Philip's Avatar
Yes they do.
If your not a commercial hauler DOT doesn't care if you have upper markers on a wider pickup. I asked a few DOT officers about that before I changed out my cab. I didn't want the factory installed roof leaks on my new cab.
BuckyKatt
Feb 8, 2013 01:12 PM
Banzai Bob
Feb 24, 2010 12:24 AM
getrdun
Nov 26, 2008 11:46 AM
eric13
Oct 17, 2005 07:05 PM
