RPM's @ 60 mph or 100 km
Old Sep 7, 2008 | 01:20 AM
timberfalls's Avatar
I have a 1990 2500 Getrag 5 spd stock size rubber and wonder what rpms am I at doing 60 mph? Thanks
Old Sep 7, 2008 | 09:32 AM
BearKiller's Avatar
This can be easily figured accurately with a little math.
Everything you need to know to figure it out is fifth-gear ratio, rear-end ratio, and tire diameter.
Most of our tachometers have been sort of guestimated, so most of our answers to your question would be inaccurate.
Old Sep 7, 2008 | 11:05 AM
12valve@heart's Avatar
Depends on your gear ratio among other things.
On MY truck with a 3.54 rear gear, 60mph (according to my GPS) comes at about 1850 rpm in 5th gear according to my ISSPRO tach that connects to the factory wiring but I have 245/75R16 tires which throw my speedometer off making it show 64mph. YMMV
Old Sep 7, 2008 | 04:36 PM
unixcowboy's Avatar
That's interesting !!
Most of the time when you go to a larger tire the speedo reads - slower --
Since stock tires are 235's how did your speedo GAIN 4 mph ??
Old Sep 7, 2008 | 05:45 PM
BearKiller's Avatar
Because a 245 is a bunch SHORTER than a 235.
The 235s are -85-s; whereas, the 245s are -75-s.
Old Sep 8, 2008 | 12:06 AM
whereswaldo250's Avatar
I'm running 265-75-16 and at 60 mph with 4:10's it is about 2,000rpm
Old Sep 8, 2008 | 09:32 AM
BINGO!! Wider but shorter by almost an inch.
In my case, it actually worked out in my favor because with the 235/85s, my RPMs were too low in 5th if I wanted to run 60 mph when towing. Now the RPMs are up higher in the torque band at 60 mph. Just about right for me.
Old Sep 8, 2008 | 11:59 AM
victoroneill's Avatar
I am stuck with 8 R 17.5 tires and need a taller tire for gearing.
I am turning about 2300 RPM at 60 MPH now.
Does anyone know how much taller 10 R 17.5 tire are if any?
I figure I've got a 4.75:1 rear axel and would like to turn 1800 at 60 in O.D.
Old Sep 9, 2008 | 01:01 PM
Thankx you guys I appreciate the info... I'l check my VIN to find out my gear ratio and Healthy Haulin and Happiness to all
Old Sep 9, 2008 | 01:04 PM
PapeCAT's Avatar
hmm 17.5 trailer tires ?
Why not just go with 8R 19.5
or 255/85r16
Old Sep 9, 2008 | 05:30 PM
BearKiller's Avatar
Back in the sixties/seventies, it was not un-common for tater-chip trucks, bread-vans, and the like, to have 17.5 wheels.
Some of the OLD motor-homes also came equipped with 17.5s.
Around the shop, unless they have went to the scrap-iron buyers, are several old 8-on-6-1/2 17.5 rims, in both SRW and DRW configuration.
The reason these rims have accumulated is due to people finding out just how costly 17.5 tires were, so they swapped on 16-inchers.
I would have long ago used them for trailer wheels, except that they are not nearly as strongly built as the trailer wheels.
Old Sep 9, 2008 | 06:48 PM
BearKiller's Avatar
Originally Posted by Scout4bta
If you have 3.54 gears, 235x85r16's, then approximately 1775 rpm at 60 mph in 5th.
VERY CLOSE
I took pen in hand and did the math for MY truck.
235-85-16 tires average 650 revolutions per mile.
Rear-end is 3.55:1
5th-gear in a Getrag is 0.77:1
In 5th-gear, each 148.1 RPM = 5-MPH
1777 RPM = 60-MPH in 5th-gear.
1629 RPM = 55-MPH in 5th-gear.
In 4th-gear, each 192.3 RPM = 5-MPH
2308 RPM = 60-MPH in 4th-gear.
1731 RPM = 45-MPH in 4th-gear.
My guestimated tachometer hovers around 1600 when the speedometer shows 55-MPH in 5th gear.
Drop to 4th-gear at 1600 and speed shows 45-mph.
At 60-MPH in 5th-gear, the tach hovers around 1800 RPM, close enough that I ain't gonna mess with it.
Old Sep 12, 2008 | 11:29 AM
Hey bearkiller can you actually see me or are you a good guesser?
I've got $5k in a '72 Commander and can get 8R17.5s for $100 each but I really need to get the O.D. RPM down or get rid of the 4.75:1 Rear axel.
I can't use 16" because of the brake calipers and will need 6 + tires of any rim change. The engine and trans are worth more than the RV so I'm 'economical'. Thanks.
Old Sep 18, 2008 | 05:09 PM
I have Getrag 5spd, 3:55 gears and 265/75/16's what do you make of the Rpms at 4th and 5th Bearkiller @ 50 and 60mph respectfully
