rough start when not plugged in
Old Jan 6, 2016 | 05:00 PM
Dylan Vigness's Avatar
Hey everyone just found this sits hopefully I can get some great advice
I'm the owner of a '93 dodge 1 ton 5.9
Just started blowing a lot of white smoke if it's not plugged in and some time s I have to crank it 2 or 3 times before it fires and than runs very rough till warm bout 2 '3 minutes again none of this happens if its plugged in. I live in Minnesota ands its about to get downright cold here and I usually cnt plug it in at work. Thanks
Old Jan 6, 2016 | 08:31 PM
Montana2x2's Avatar
White smoke and cranking a few turns to start sounds like air getting into the fuel system.
Old Jan 7, 2016 | 04:00 PM
Is there a specific place i should look and if there was air in the lines wouldn't it do this all the time? Thanks
Old Jan 7, 2016 | 04:18 PM
Montana2x2's Avatar
Look for leaks in the lines from the tank also the fuel heater gaskets tend to dry out and leak. The lift pump can also cause problems. I think the symptoms show up more when it's colder. Just a place to start.
Old Mar 6, 2016 | 09:47 AM
kodiakken's Avatar
What are you calling cold enough to be plugged in?
Up here in Canuckastan I have started these old dogs after they have sat out side all day at 10F below and yes they smoke white as the cylinders are cold and the fuel is just getting to ignite, in 5 minutes or so they pretty much clear up and are good.
They always go back to normal once they get fully warmed up.
Cold is he!! on Diesel engines.
If you have ever seen an old 350 or 400 big cam start when cold it is the same thing.
Old Mar 7, 2016 | 08:22 AM
j.fonder's Avatar
so your diesel starts a little harder and smokes a bit when it's cold? that's not a problem, that's normal.
make sure your grid heaters are operating and let them cycle twice before you start the truck.
doesn't sound like you have any problem at all, it's just cold.
Old Mar 13, 2016 | 09:06 AM
ofelas's Avatar
Theres this small contraption that heats & circulates coolant through the block & heater core with the engine off.
45 minutes of the above & the grid heaters never come on in 25 below freezing.
Old Mar 13, 2016 | 09:30 AM
mknittle's Avatar
I used to stand and watch em blow big puffy smoke rings. Somtimes it would blow one ring through another the good old days.
031tun
Dec 1, 2012 08:45 PM
Dlowkes7
Jan 13, 2011 11:05 AM
marc eber
Jun 12, 2007 09:34 PM
Dodge2003
May 11, 2007 08:05 AM
Garverless
Dec 12, 2002 01:44 PM
