Rockcrusher wheels
Rockcrusher wheels?
Anyone know which wheels fit my 92 D250? There are so many I don't know which ones to order. I want to use my standard 235X85X16 tires as they are new. The offset, backspacing and so on is confusing my brain. The ones I have on it now are 16X7 8 lug on 6.5" according to the invoice where I ordered them. This is what I am looking at but need to know if I am right.
Polished Rockcrusher Wheel 16x8 8x6.5 -20mm 3.625 5.150
SKU #: 1JA 860920 Mfr #: 887-68080
Backspacing:3.63 in.
Color Finish:Machined/Polished
Condition:New
Design:Hole/slot
Includes:Center capLoad Capacity:2500 lbs.
Material:Aluminum alloy
Numberof Lugs:8Offset:-20 mmP C D:6.5 in.
Series:Allied Wheel Components Raceline Rockcrusher Series 887Wheel Diameter:16 in.Wheel Width:8 in.
Or maybe these,
Polished Rockcrusher Wheel 16x10 6x5.5 -24mm 4.5 4.250
Am I right? They are non-returnable so I have to be sure.
Condition:New
Design:Hole/slot
Or maybe these,
Measure the backspacing on your old rim. This is from the face of that contacts the hub to the inner edge of the bead. Then measure how much clearance you have from the brakes, etc. Add the two together and give yourself a reasonable amount of space between the rim and the brake parts. That will be your maximum backspace that will fit.
You want the 8 on 6.5 bolt pattern. 8 lugs, 6.5" apart center to center.
spoolinup
Jan 3, 2010 02:38 PM
Dave88LX
Jul 13, 2005 08:34 AM
Gary C
27
Mar 11, 2004 07:42 PM
