replacing dash bulbs
Old Dec 22, 2002 | 10:38 PM
Garz's Avatar
I removed the screws holding the dash so i could access the bulbs, but wasn't able to remove it. Whats the trick to this, and what's the easiest way this is done? [undecided]
Old Dec 23, 2002 | 11:00 AM
Lil Dog's Avatar
Re:replacing dash bulbs
The problem is that you have to release the speedo cable from the back of the dash head. There is a clip that you have to press up I believe, like away from the cable end.. I hope this make sense, but you sort of have to do it by feel as I couldn't get a good look at it in place. Once you have that unhooked you can remove the dash pods.<br><br>Also you may be able to get some more room by feeding the speedo cable from under the hood and pushing a bit.<br><br><br>Good Luck<br><br>J-eh.
Old Jan 4, 2003 | 10:42 AM
Grey Wolf's Avatar
Garz,<br><br>I'm not sure if the dash is the same on yours but my '93 and my sons '90 have several tabs on the dash face that slide into the sub base of the dash. Once you remove the all screws you have to tug on the dash face to get to to come loose. The instrument &quot;pod&quot; is held on with screws and there isn't a speedo cable on ours, it's run by an electronic sensor and wire.<br><br>Hope that helps
Old Jan 5, 2003 | 12:07 AM
Craig93's Avatar
When you find out let me know.. I just snaked my arm up from underneath and changed the temp gauge light, fairly painless...also need to change the volmeter gauge light...need to remove the gauge cluster for that one...
Old Jan 6, 2003 | 10:05 AM
Lil Dog's Avatar
The 89 units were a mechanical speedo.. I had one.<br><br>The 91 and up models are electronic.<br><br>J-eh
Sierra1
Jan 23, 2016 12:02 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
skymiles
Jan 20, 2007 11:11 PM
Ridiculous
Dec 21, 2006 11:02 PM
coobie
Feb 19, 2004 03:45 AM
