rear spring question
so im looking to raise the rear of my truck 2" im thinking i would replace the rear stock springs and blocks with some 6" springs do you guys think it would be around 2" higher??? or do i need 8" springs?
thanks gary
thanks gary
I would just add another set of block's it won't hurt unless you are going to run maybe the Baja 500 I had double stacked block's on my last truck and it never slowed it or hurt it in My oppinion and I am sure you will get other answer's .
I put on springs from stengle brothers that raised the rear more than 2 inches just because the stockers were dead. depends on what you want out of the truck.
Its a pullin truck, I kinda want to get rid of the blocks and don't really want longer u-bolts do to flex under extreme loads when sled pulling. but im looking to jack the rear up a couple of inches.
Id do the 8" rear springs, because the 6" rear will probably get you only 5". Then maybe a 2-3 block would get you where you want. The 8" rears will get you close to where you want to be. I wouldn't even consider adding another 2' block on the stock 6'' block.
DNRCustoms
11-24-2008 09:30 PM
WhoCares79
06-03-2008 11:45 AM
flynhigh205
02-26-2008 10:33 AM
fishin fever
03-13-2006 06:46 PM
