Rear disc conversion thread.
I was able to put the calipers on the correct side with the bleeders facing up so I didn't have to take them off. The brakes work great just the pedal is a little squishy. I expected more travel and little bit more squish though. I may have all the air out but I'll bleed it again after a few days.
This is what I used to complete the conversion.
From Auto Zone
C529 & C528 brake calipers $16.99 each with $18.00 core charge for each
They should come with the pins, brake line bolt and washers.
From Summit Racing
2- Russel 20" long brake hoses. RUS-657370 for $27.97 each
Classic Industries brake line mounting tabs CLP-RBHTK $14.97
From Rock Auto
2-Raybestos rotors 5014R $27.99 each
From Great Lake Off Road
Dana 70 disc brake brackets GLO-DSKBR-70 $50.00
Spacer material (cut to fit tubing) $12.00
From Advance Auto Parts
Front brake pads CARQUEST Wearever Gold GNAD52 $37.99
And 2-4 1/2" band clamps I picked up at Auto Zone for $3 and some change and 1 quart of DOT 3 brake fluid which I already had.
The bolts that came with GLO brackets weren't long enough so I bought 6 grade 8, 1/2" by 3 1/2" long bolts and lock nuts at the hardware store. About $15.00 The 6 washers I used were left over ARP items from a main bearing girdle kit for my race car. I'm sure you can buy them separately if you wish from ARP.
So right around $315 plus some shipping and sales tax.
The more I drive it the better the pedal feel has gotten. The brakes are definitely better than they were before. I can still lock up the rears though even on a dry road. I still need to do the front calipers and pads and I'm going to put steel braided flex hoses on the front as well. I will update this later when I have it all figured out.
From Auto Zone
From Summit Racing
From Rock Auto
AJ, I've been reading up on those adjustable proportioning valves, and looking at the ones on Summit and Jegs. While on the Jegs site, they had a link to a PDF on installation instructions, and here is what it says, not quoted- install adjustable prop valve after the master cylinder and after any factory distribution block or balancing valve with the brake switch. Make sure there is NO ABS TYPE SYSTEM down hill from the placement of the proportioning valve.
Just thought I'd let you know, as this kind of coincides with what we're discussing on our PM's.
I ordered one of those Aerospace valves and I'll let you all know how it works.
I can understand not having an ABS system downstream of the valve as the module would have pressure sensors in it and a reduction in pressure to the unit would cause it not function properly. Since our trucks have an isolated rear wheel only system that basically just dumps pressure it shouldn't matter. It is really no different than not applying as much pedal pressure.
Me, personally, and I'm not locked into this, my 93 has a distribution block mounted right on top of the frame rail, directly underneath the steering rag joint. I was going to disconnect the brake line heading towards the rear, then add a 90 degree fitting of some sort to that port at the D-block, run a line up towards the MC somewhere, mount my Adjustable valve, plumb a line back down from the adjustable valve and reconnect to the brake line I disconnected from the D- block, the one that heads towards the rears.
Been reading up on these pressure residual valves also, the ones that work like a check valve. 10 psi, red colored ones for drum brakes, 2 psi rating blue ones for disc brakes. Think I'm going to add one of those, too, along with the aerospace unit.
Augie, I don't know what you are trying to accomplish with the residual valves. The only use I know of for them is if the master cylinder is mounted below the calipers or wheel cylinders as it is in some street rod and tube chassis race car or off road applications.
I have the valves on my race car because the master is mounted below the floor with the reservoir through the front floor aluminum below my legs. This keeps the fluid from flowing back into the master cylinder. Since the master on our trucks is the highest point of the system the residual valves are not used.
For drums, they maintain a steady 10 psi of pressure in the lines, not allowing any air to ingest into the system( via the drum cylinders) every time one were to release the brake pedal. If your cylinders are questionable, old, or if one doesn't have his rear brakes adjusted perfectly, air could siphon in thru the tabs that push on the shoes, upon brake pedal release. This here RPV is cheap insurance, and any help in bettering the drums on these things is always a plus.
Feel free to school me, if I am way off base on my thinking. I'm just learning as I go along.
I don't see the benefit to adding the valve on these trucks. The wheel cylinders are still going to expand and contract. The only way for air to enter is it would have to pass by the cup inside the cylinder. The outer boot is really just a dust seal.
Weird how dodge in the earlier years mounted that Balancing valve with the brake switch; some had it mounted at the frame, and others like on my 93 have it 4" below the MC.
If it is just a plenum of some sort, and the front and rears do not mix, then that Aerospace unit can even mount before it, as long as it is after the balancing valve that's below the MC(speaking for a 1993 model), correct?
That is correct. It's just a block and there is no connection there. You could (and I may) just tee the three lines for the front together and connect the rear two lines to the adjustable valve there and just toss that junction block.
I've heard it called junction block, distribution block, and one more that I can't remember- is that basically a plenum(my type of lingo)? The front and rear fluid passages do not mix in there, correct? I see it as the lines coming from the balancing valve dive on top of that thing, and shoot out the sides towards either the front brakes or the rears. Every time I try to describe that thing, others call it THE proportioning valve, and I have to explain that there is no brake switch on it, so it cannot be.
Edwin, not sure on your model years, but what AJ and me are talking about, on our trucks (mines a 93 model year) there's the master cylinder, then approx 4" below that is the balancing valve, that the brake switch connects to, then the brake lines head straight down onto this junction block. That's what we were talking about getting rid of. Your balancing valve on your 89 is mounted at the frame. That's what I was mentioning earlier, how weird it was that Dodge mounted it at the frame in the earlier years, then up and under the MC in the later years.
