Rear disc brakes anybody try this?
1 Post
Found this on pirate4x4 http://www.pirate4x4.com/forum/inter...fat-***-2.html LINK not working go to post #4
This guy is using a 14bolt with hmmwv wheel. Brakes are from a 99-08 chevy
Could this be done on D70 and use standard 16'' wheels.
While I agree the internal drum e-brake is a better design there is nothing wrong with the eldorado calipers. The single most important thing with them is to properly adjust them before connecting the brake hoses and bleeding them.
Install them, with the spring off the e-brake arm, ratchet them up until tight, reinstall the spring, connect the brake cables and adjust the e-brake then install the brake hoses and bleed. Then recheck e-brake adjustment.
I worked on many back in the day and they used the same caliper type on the anniversary model Trans-Ams
The link takes you to a thread that give you another link. The guy built a setup using "I think all Dodge pieces". My puter crapper out so I'll research further later. It seem he did alot of fabbing and designing to use off the shelf parts "almost". Cool setup though even better to have a spare rearend to do the mods on and not having to rush.
1 Post
This is from a 99 E350 SD
http://www.pirate4x4.com/forum/newbi...l-e-brake.html
Guys instead of trying to make the e-brake work on rear disc conv. why not use something like a hurst line lock? That would lock the discs on front and release with the touch of a button.
