rear diff questions
Old Nov 16, 2013 | 02:24 PM
haultruck's Avatar
rear diff questions
So heading to work the other day, I grenaded the pinion in my rear diff. I was lucky enough to coast into a transmission shop that said they would have a look at it, and give me an estimate on fixing it. They said it would be $1000-$1200 to do everything accept axels and wheel bearings. I thought that seemed really high and said I would get back to them. I started looking for a whole diff and can't find a Dana 70 dually with my same outers. I started looking at replacement parts, and found that they're a little more expensive for name brand stuff than I thought they would be, unless I'm looking in the wrong places. I'm also wondering how hard it is to do myself, because I've never done one. I've had a few guys tell me that it's easy, but they're hacks. I'm a bit of a perfectionist, and if I can't do a professional type job, I'd rather not try. With that being said, I'm pretty good at turning wrenches, and I've never had a shop work on my rigs, ever. So before I make any decisions, I'd love to hear your guy's thoughts/advice/experiences. Appreciated as always, thanks.
Old Nov 16, 2013 | 05:20 PM
BC847's Avatar
1st Generation Admin
Get the FSM (Factory Service Manual), the hard-parts, and enjoy doing it yourself.
Informative links in this post should prove helpful: https://www.dieseltruckresource.com/...75&postcount=1
Old Nov 16, 2013 | 10:59 PM
bigredbrick's Avatar
$1,000 to $1,200 is a deal, but if you pay someone you want that person to do it all the time, there's some "art" involved in setting up the gears. Chances are a carrier bearing has spun, common problem with Danas, and if that has happened the carrier might be salvageable with some machining. If you have a Powr-Lok the replacement cost is close to $900. Parts prices have gone thru the roof lately. Dana/Spicer ring and pinion around $350. Doing it yourself takes some special tools and set-up bearings are nice, which you can make yourself with the old ones if they are ok. I once swapped everything from a dana 44 rear into a new housing, but I didn't mess with shimming bearings, kept everything as it was. It didn't sing or whine but I didn't put a lot of miles on it either. Read everything you can on how to do it and figure what tools you will need to buy and decide if it's worth it.
Old Nov 17, 2013 | 07:34 AM
BigIron70's Avatar
Cummins Guru
I agree anyone can throw parts in a housing but will it be quiet and last is another story. If they standby their work it's not a bad deal. Dana 70 are not the easiest diff to rebuild since every adjustment is done with shims. Notorious for carrier bearing race to spin in housing with these also. I just did one which had a spun bearing race and had to pull housing from truck to send to machine shop for repair. No housings available nation wide. Lucky that customer had a service contract.
afate45
Jun 7, 2014 12:08 AM
jlandry
Jan 31, 2011 08:29 PM
banana
Dec 1, 2009 11:44 PM
jpfishmaster
16
Aug 12, 2009 12:37 PM
USMC64-70
Nov 10, 2002 02:59 PM
