Pyro moving like the boost?
Old Sep 19, 2006 | 01:51 PM
csramsey640's Avatar
Ok while on the road hauling today, I was running about 850 deg after turbo, and had to let off to shift. upon letting up on the pedal, I lost my pyro-all the way down to 0. when I got back into it in 4th gear, it came back up almost right with the boost needle. Same deal all the way home. Except it sweeps up to the usual numbers and wont go higher like the boost will, back off and she drops right back down.
Im stumped. I check my connections and atleast they seem still tight.
Old Sep 19, 2006 | 01:58 PM
haloman's Avatar
Double check that you have a good ground
Old Sep 19, 2006 | 02:28 PM
goodtyms's Avatar
My guess is that you either have a bad connection or a bad t-couple. EGTs don’t swing that fast or that far (zero).
turfguy
Apr 17, 2014 11:36 PM
ebgpag
Jan 14, 2010 08:42 AM
mtl0727
Jul 30, 2009 09:42 PM
alwaysfaded
Mar 1, 2007 01:09 PM
