pyro ?
There are plenty of posts with links to the install of the probe.
Here's one on the Piers site
http://www.piersdiesel.com/TechPyroInstall.htm
I just did one last weekend and it was real easy. The hardest part was getting the turbo off the exhaust manifold.
Den
Den
Just as an addition to those instructions...drill straight and when you do the tapping don't go too far, it's a tapered tap and you don't want to make the hole too big or the pyro insert won't have a tight fit. You are trying to get about 3-4 full turns on the pyro fitting. That is enough thread to hold for you and will make sure that you don't have an overly large hole.
Also, try to keep the pyro tip about 1/2 way down the passage and be sure that you don't let it touch anyting...like the bottom of the manifold passage...it has happend and they can break if you do that.
pb.....
pb.....
FiverBob
24
Nov 27, 2002 03:32 PM
