pump timing
Old Dec 29, 2014 | 10:32 PM
DOZENVALVE's Avatar
pump timing
I would like to adjust my pump timing, and I have a dial indicator so that I can measure actual pump lift in this video it shows how to do this between about 4:30 and 5:30
two questions
1) what mount is he using there on that dial indicator, I only have a magnet style like what is used for doing rear ends and such
2) if I had the proper mount, what is ideal lift for bosch 190's, or is it something id have to toy with
if its something to toy with, may as well give her an 1/8th and be done with it.
Old Dec 30, 2014 | 12:44 AM
DOZENVALVE's Avatar
I just went through this sticky...
(Type a title for your page here)
and it says the adapter is Volkswagon special tool 2066
I may be onto something/answered my question #1 (partially)
Old Dec 30, 2014 | 08:09 AM
j_martin's Avatar
I made the tool with a drill press:
1. Drilled a 12mm hole in a wood block (1.5")
2. Put an m12 x 35 cap screw in the hole.
3. Used the hole to guide a centering punch.
4. Put the bolt through a piece of scrap 1/8" steel.
5. Used the jig to drill a 6mm hole through the bolt.
7. Sawed the head off the bolt.
8. Drilled a 12mm tap hole through a 3/4" x 1" piece of aluminum round stock.
9. Drilled a clearance for the indicator half way though said stock.
10. Threaded the other end 12mm
11. Cross drilled and threaded a 6-32 hole for a lock screw.
12. Put the drilled stud into the round stock with a drop of loc-tite.
13. Installed a 6-32 thumb screw.
Old Dec 30, 2014 | 11:05 AM
DOZENVALVE's Avatar
nice. is there a good ballpark number to set the timing to?
Old Dec 30, 2014 | 05:20 PM
j_martin's Avatar
Stock is 1.25mm at TDC.
Old Dec 31, 2014 | 01:02 AM
DOZENVALVE's Avatar
I see that on my timing case there
Old Dec 31, 2014 | 08:48 AM
j_martin's Avatar
If you PM me with your e-mail address, I can send you the couple pages of the FSM that cover pump timing.
Old Dec 31, 2014 | 10:53 AM
DOZENVALVE's Avatar
i just remembered I have an FSM now haha. ill look there for details, thanks
GR40RCapri
Jul 24, 2006 11:47 PM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
