plow controller
My switches are mounted in the dash, I made a small flat panel from aluminum and just screwed it in place. When you shift into drive, the switches are at your fingertips! One hand steers, the other flicks the plow into action!
What wiring do you have with the switches?
i dont have much for wiring, just the power solenoid and for the pump its self. no wires for the lights. i am having a hard time trying to tap into the system. any ideas? the toggle on the panel has two pair of wires with plugs on the end. anbody with this setup look and see what it goes to, and/or take a picture of it?
The original wiring harness makes installation child's play.
I will pull my panel out and snap a pic. With that, you should be able to duplicate the set-up.
I have had this set-up installed on 2 trucks, the first being a '89 Chev half ton. The Chev has indivual lamps for high and low, not easily converted to a 3 prong harness, so I never bothered with the aux. lights. My Ram is tall enough that again, I have decided to forgo the aux. lights.
