please help no brake lights
Old Apr 24, 2011 | 04:56 PM
d3504me's Avatar
My truks previous owner hacked it to pieces. My hedlight switch plug is gone only spade connecctors to hook it up but my question is would tht affect my brake lights I have normal funtion on everything but my brkelights does anyone know how to hard wire them so they will work what wire to connect if they eevenn are affected by the hedlight switch at all. Any help would be greatly apppreciated thanks in advance.
Old Apr 24, 2011 | 05:11 PM
ofcmarc's Avatar
Brake lights don't go through the headlight switch. They are on their own fuse and switch. Look for a bad fuse at the panel under the steering column. The switch is attached to the brake pedal and is fairly easy to get at and test.
Old Apr 24, 2011 | 07:06 PM
1992gen1_fan's Avatar
If the PO had a trailer brake controller, check the wires to the controller. I went without brake lights for almost a year and finally found a bad wire splice in the steering column where someone tied in the controller.
Old Apr 24, 2011 | 07:09 PM
NE frmhnd's Avatar
It could be the brake light switch/ brake pedal stop needs adjusted.
corygale
Jul 24, 2010 11:37 AM
polaris800sp
Nov 13, 2008 05:35 PM
SuperiorRam
Mar 15, 2007 03:10 AM
