piston lift pump won't keep up
Just installed the low pressure piston lift pump (3936320) on my truck this morning. At idle it puts out 14psi
which is much better than the 4psi from my old pump. with the piston pump no load psi tops out at 16 psi around 2k rpms then drops to 12 at WOT no load. Sounds good right? Well i took it on a test drive and i can suck the fuel pressure down to 0 in third gear at 2700 rpms
. I could only get the pressure down to 0 in 5th under full load at 2500 rpms with the old pump, in 5th with the new pump the fuel psi gauge drops to 0 very quickly when i get on it. What's the deal???
the question is did you buy this pump new or used
Fuel filter, heater etc. should be fine. Like I said, right before I changed the pump pressure was ok, just low like always. I only have 500 miles or so on this filter anyway.
You guys all running the spacer between the pump and block? I assume you have too, its tight enough with the spacer. I was just thinking, doesn't that spacer shorten the effective stroke of the pump therefore decreasing flow?
Without the spacer you will quickly bend or break the pump's rod. Upgrading your fuel pickup tube and line to the lift pump will help keep pressure up to the injection pump. It doesn't take much to suck the 5/16 hose dry, along with the even smaller pickup in the tank.
It should still do better than that. He's running stock injectors, from what I see in the sig, and still seems to be doing even worse under load than the stock pump that was on there before.
Are you sure you don't have an air leak? Pressurize your tank, maybe the fitting on the inlet side of the pump is leaking?
On my truck with stock injectors, making 20psi manifold the pump hasn't been under 10psi.
