Pilot bearing
Pilot bearing
After much reading about the pilot bushings upgraded to a bearing I have a couple questions. First does anyone have a part number of the bearing? How many here have gone this route and would they do it again?
Lots of vehicles use bearings, mostly imports that I have worked on. Bushings do wear out especially if they get greased on install.
Call South Bend Clutch they have an impressive pilot bearing. You will need to have your flywheel machined to accept this bearing. I saw it at PDRs dyno day a few years ago and it was impressive.
Bob
Bob
I just had mine done at southbend clutch yesterday. I can get a P/N off it later on if there is one. I drove it out there and they surfaced and bored it out for a pilot bearing in 45 minutes. It came out sweet!
If there is a number on it and you could check, I'll verify that I got the right one.
Bearings are not good for a daily-driver/work/towing rig.
The bronze bushing is still the best.
There are many threads, here and in other forums, of the bearings siezing and eating the tip off the main-shaft.
I debated this same scenario, when I was swapping the engine into my Ford, and I went with the tried and true bushing.
Most import vehicles use (ball) bearings on the pilot and they are great. My bushing was really worn so when I read about changing to a bearing it sounded like a great fix..Ok, just did a bunch more reading. The newer generation trucks used a needle roller bearing that fails miserably and takes out the input shaft. I have seen this on Ford Rangers and stuff so I do beleive that. As for a ball roller bearing I think that is far better than the oilite bushings. Just my .02 but time will tell. I'll be having the flywheel machined to accept it.
I had a bearing go out and it took out my input shaft and primary countershaft gear. I went back to the bushing and have had zero problems since. When a bearing goes, you get enough of an angle to take out parts. The bushing wears very slowly, and can't go out all at once.
Bearing or bushing, neither are turning, so long as the clutch is not depressed.
What kills both are long periods at lights/etc., holding the pedal down, thus causing the shaft to spin in the fly-wheel; this also spells death for the throw-out.
For any idle spell over a couple seconds, put the transmission in NEUTRAL and let off the pedal.
So long as the clutch is ENGAGED, there is no wear or stress on the pilot.
I have an old clutch-eating 400,000-mile Chevy, that has had probably no less than a dozen clutch replacements; the bronze bushing that GM put in it in 1978 is still in there and going strong; the new one that I bought for the first clutch replacement is still in the glove-box.
I am curious to find out how long this bearing will go for. Its a nice sealed ball bearing. My bushing in there was toast and ate the input shaft. I agree the fact that the operator has alot to do with how long all that stuff will last.
