pidley turbo mods
Old May 29, 2007 | 10:27 PM
bloodhound51's Avatar
pidley turbo mods
looking for some turbo mods (DREMEL MODS ETC.) to pass some time in the shop until my next purchase
will porting and polishing the compressor side of the turbo net any gains
or exhaust housing mods
i no not to mess with the areas around the wheel but what about the areas that are funnel shaped in front of the wheel and the backing plate etc.
just some past time mods.
i have a turbo off of 1989 3500 i've heard these have a better wheel in them is this true?
Old May 29, 2007 | 10:33 PM
rbrettctd's Avatar
I think they are a little bigger. The best thing to do IMO to not spend too much is find a compressor housing from a I/C H1C, (4" in/2.5" out) and build a custom crossover tube to accomodate it. Im doing this, only with an HX35.
Old May 29, 2007 | 10:34 PM
gman07's Avatar
You can port the inlet on the turbine housing to match the manifold, or even slightly larger. I don't know if 350's had a better wheel or not. The most commonly used measurement on this site is the diameter of the inducer, or small part of the compressor wheel. Porting the compressor housing probably won't gain you much.
Old May 29, 2007 | 11:09 PM
edwinsmith's Avatar
To do the H1C to WH1C conversion you need both the wheel and the compressor housing. You need to grind off the flange and use a 2-1/2 to 2 inch adapter hose to mate to your stock crossover. I did the 12 cm WG housing also and I am very pleased with the result. Look in my gallery for photos.
Edwin
Old May 30, 2007 | 07:05 AM
rbrettctd's Avatar
THe one I am talking about is not WH1C. Just H1C. Ours is the baby version.
Old May 30, 2007 | 09:16 PM
city slicker's Avatar
I dont mean to jump your thread but, I would like to know how you mated the 727 to the ford NP205 thanks
Old Jun 1, 2007 | 12:35 PM
finally someone asked me that
we actually used a 75 model divorced np205 and a 2 wheel drive 727
i questioned the strength of the divorced setup but it seems up to the task.
Old Jun 1, 2007 | 10:39 PM
Caver Dave's Avatar
A bud of mine is pushing 2 divorced 205s with a FI 455/TH400 twisting welded Rockwells on 44"s... if his monkey Edit hasn't broke them...
tristan21
Jun 19, 2007 04:57 AM
Lark
18
Feb 12, 2007 06:34 PM
Flatty
Nov 16, 2005 08:39 AM
blownaway
Mar 13, 2005 11:57 AM
