(Pics) Where the fuel pin isn't delivering more fuel.
Old Oct 24, 2010 | 02:37 PM
jimbo486's Avatar
That's what I'm interested in. Trying to minimize low end smoke as much as I can. Especially living here in Commiefornia. Looking at my fuel pin or cone, I'm reaching the deepest part of it. I haven't touched my smoke screw and my starwheel is up about 4 turns from the stock position to increase the spring tension but I now believe that all that did was make it even easier for the spring to fully compress. Easier as in, less than 10psi. I replaced the nylon washer/spacer under the diaphragm in favor of an o-ring that fits snug around the shaft of the fuel pin to achieve full travel. If I let the clutch out in 3rd and push the pedal to the floor, it pours coal! I know that's lugging it but I don't do it often. Just when I need to get my revenge on ignorant drivers .
Old Oct 24, 2010 | 06:15 PM
The_Head's Avatar
It's interesting if the spring is fully compressed at 10 psi. It almost defeats the purpose of the AFC if you ask me.
Old Oct 24, 2010 | 07:40 PM
KD93's Avatar
I don't know about you guys, but I can remember when my truck was bone stock, it didn't haze at all. I haven't messed with mine barely at all. It doesn't take much to get it smoking. Point is, a 10psi spring was plenty when the truck was stock. Seems to me that pushing 40psi or whatever, chances are pretty good a stiffer spring will help.
Old Oct 24, 2010 | 09:11 PM
BC847's Avatar
1st Generation Admin
I run a boost-fooler feeding the AFC on my mess. I've got it set up for a .5/1 ratio. 20psig in, 10psig out, 30psig in, 15psig out, etc. That combined with having the Star-Wheel turned up pretty stiff along with the smoke-screw backed all the way out in a machined cover.
Thomas with M&H cut me a custom fuel pin that pretty-much mimics the factory ramp profile, but with the added depth. As such, the AFC doesn't come on so strong with low boost.
With that, it's still touchy controlling smoke. Got to roll into it with no jabbing the throttle.
Old Oct 25, 2010 | 01:11 AM
schamran's Avatar
Am I understanding this correctly Justin? The pin inside the pump does not come in contact with the deepest part of the DennyT fuel pin, correct? If so, why not make a pin with a steeper angle cut into it?
Old Oct 25, 2010 | 08:35 AM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
Yeah exactly... It doesnt actually touch the deep part of the denny t.
What do you mean by steeper angle? I could see doing a pin that only ends up with 1/4" of material at the 23/32" point.. if you can imagine that.
Old Oct 25, 2010 | 10:04 AM
schamran's Avatar
Yeah that's what I was getting at. You would have to change the angle of cut to do that.
Old Oct 25, 2010 | 12:38 PM
cougar's Avatar
Your pin should travel more than that. Just a SWAG, but check the diaphragm for a pin hole or leak around the threaded end.
Old Oct 25, 2010 | 12:49 PM
cougar's Avatar
Something nagging me and I think it is that picture of your modified AFC cap. Can you repost it?
Old Oct 25, 2010 | 03:17 PM
the pin travels up and down, i know for sure... i have my pump apart right now and i made the marks by moving the fuel cone up and down and the lever/pin by hand... the diaphragm isnt part of the equation. maybe ill tape a video of how i have done this.
Here's the pic of my pump top... i know for sure that the fuel cone has full travel up and down in the pump.
Old Oct 25, 2010 | 04:00 PM
Here, i made this video real quick to show you what i did... dont mine my gibberish. Sorry you can't see the internals of the pump, they showed up in the cameras screen just not on youtube.
http://www.youtube.com/watch?v=C2QO9V7mH3o
Old Oct 25, 2010 | 06:34 PM
The_Head's Avatar
Why is your pump top chewed up like that? It looks strange.
Old Oct 25, 2010 | 06:52 PM
tried using a grinder... didnt work.
Old Oct 25, 2010 | 09:27 PM
fatt's Avatar
So in other words all aftermarket fuel cones are a total waste of money?
Old Oct 25, 2010 | 09:29 PM
im not saying anything for sure because im not an expert and i might be missing something... but it seems like it doesnt it?
