PDR custom injectors??
Old Jul 28, 2009 | 01:54 AM
SMKHZRD's Avatar
I had on order some 6x.016 from new era, but they are on back order and they dont know when they get them in...so called pdr and they could make some 6x.012 that they have in stock for little over $500..anybody running custom injectors from them...thanks
Old Jul 28, 2009 | 08:23 AM
apwatson50's Avatar
PDR has a pretty good reputation. I think a 6x.012 size injector would make some pretty good power with little idle haze, assuming the injectors are put together right. Do you know if the tips are EDM'd or extrude honed? Also do they do anything for pintle lift?
Aaron
Old Jul 28, 2009 | 06:54 PM
SMKHZRD's Avatar
they are EDM......
Old Jul 29, 2009 | 08:31 AM
apwatson50's Avatar
That is good that they are EDM, you should find out if they do anything for pintle lift, or anything internal to the body. Other than set the pop-off pressure.
Old Jul 29, 2009 | 06:49 PM
peobryant's Avatar
Personally, I would wait for the 6X.016 injectors to come in. They will support more power than the 6X.012's.
If all you want is around 400rwhp, the 6X.012's would do that I'm sure, but you'd have to have the pump cranked up more than if you had the 6X.016's.
You won't outgrow the New Era's unless you go to twins...
95ram12v
Jan 5, 2008 04:12 PM
Txwelder
14
Nov 11, 2007 04:28 PM
Sootin
May 25, 2007 09:33 PM
A-Poc
Sep 1, 2005 01:23 AM
Hawkeye
Sep 23, 2003 08:22 PM
