PCM Regulaior Voltage ????
Old Nov 15, 2013 | 09:42 PM
whosdunit's Avatar
Truck--91.5 d250 ---PCM regulates voltage by switching grd. rapidly. Is this the reasonmy amp gauge(and test light ,on gren wire on the back of alt., ) "BLINKS"??? Would a internal reg fix this problem????.
whosdunit.
Old Nov 15, 2013 | 11:36 PM
Philip's Avatar
A 91.5 model has a external regulator. It should be mounted some where on the firewall around #6 valve cover.
Old Nov 16, 2013 | 01:22 AM
whosdunit's Avatar
Yes .sir it does ,my problem is --it is pulsing at idle, and my amp gage flips back & forthand since the pcm don't need the alt., input --wouldn't a internal regulator fix my problem.?
whosdunit.
Old Nov 16, 2013 | 07:13 AM
sooty's Avatar
yes, some put the 150 amp ir gm alternator, as another alternative look at jims post with leece nevill, I like the easily accessable brushes and regulator, mine pulses at startup, usually from camper battery being down, after a minute of running its normal.
Old Nov 16, 2013 | 08:22 AM
whosdunit's Avatar
Thanks guys ,,headed to alt. shop this morning to see what it will cost,,and get grd., cables via the sticky.
whosdunit.
imbodie
21
Jan 8, 2024 08:49 AM
powerrammaster
Jul 20, 2008 08:17 PM
fryedaddy
Jan 6, 2008 06:09 AM
Big Perm
Dec 18, 2007 08:44 PM
