parts swap 93 to 90?
I recently got a '93 d250 and plan to part it out with what ever I cant swap over to my 90 w250. I'm going to grab the intercooler and grill as well as the wiring harness, if it will work? any suggests on what to take from it besides motor items?(going to sell that complete)
Well i'll just transfer the whole front I guess, my real concern is will the wiring harness from 93 to the 90 work because my 90's is a farmerized mess and I wouldn't mind having cruise and that high idle i could do with it in winter.
You will have issues with the steering column wiring, the KSB is wired a little different.the rest you could make work if you switched the whole harness, computer and maybe add a couple of sensors to the engine, like the crank position sensor.Maybe see if the whole column would fit in the 90 then you could use the switches on the 93 column and the plugs would match. When I changed the wiring in my 93 I found it was easier to switch the whole dash than to just pull the wiring out.
Checkmate
03-02-2008 05:55 PM
BRUISER
05-02-2007 09:20 AM
CTD_Neil
07-19-2005 08:13 PM
xj2extreme
02-20-2003 10:38 PM
